Wi-Fi implementation
jplenbrook
Level 2
Level 2
Hi All,
I will be looking at implementing brand new network at one of our offices with about 300 users in September.
I will need to implement a solution that can support multiple SSIDs, PoE, multiple vLANs, dual band and can be managed with a wireless controller preferably to avoid going around each single AP to make changes. This wireless solution will need to allow our wireless VoIP phones to make phone calls providing QoS.
I am completely new to Cisco wireless so any ideas would be greatly appreciated!
This project will include provision of APs, switches to interconnect and probably a router as default gateway or maybe ASA. Not too sure what will be more suitable in this kind of scenario. Also our VoIP system is hosted by third party so we will be connecting to outside system.
Best Regards,
Reza Sharifi
This a whole new design. Contact your local Cisco sales rep to setup meeting to discuss the features and functionality you need. If you are new to Cisco product, you may want to hire a consultant or ask Cisco to help you with the design. They will be more than happy to sale you products.
Reza Sharifi
Thanks for that. I think this is a good way to go on about it. Will give them a call soon!
If you need to deploy this by September, you should start the discussion sooner than later.  You need sometimes for product presentation.  You also need sometimes for evaluation and design. Next comes ordering and lead time and finally deployment.
BTW, we tested a couple Cisco 5500 wireless controllers in the lab.  They are pretty solid.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Wireless VoIP (with QoS) - very bleeding edge.
You may want to obtain professional consultation.
