01-11-2018 12:29 AM - edited 03-08-2019 01:22 PM
I have cisco 1921 router running with " c1900-universalk9-mz.SPA.152-2.T.bin" kindly confirm whether 1921 router will support WIC-2T card.
If possible please share cisco documents.
01-11-2018 12:45 AM
should do if its a hwic-2t
Table 3. Supported Platforms and Quantities
01-11-2018 01:24 AM
As it is wic2t can you plz clarify whether it will support the 1921 router
01-11-2018 12:46 AM
The datasheet on the WIC-2T predates the release of the 1921 ISR, so doesn't list the router as supported:
This document shows that WIC cards are compatible with the 1921:
01-11-2018 01:27 AM
So which means cisco 1921 Router will not support WIC 2t card
01-11-2018 01:32 AM
The latest documentation indicates that all WIC cards (including the WIC-2T) are supported on the 1921.
01-11-2018 01:34 AM
Can you share the document which is showing the same.
01-11-2018 01:53 AM
01-11-2018 07:06 AM
Hello
I would say it does-
Host7#sh ver | in System image|CISCO1921
System image file is "usbflash0:c1900-universalk9-mz.SPA.154-3.M3.bin"
Cisco CISCO1921/K9 (revision 1.0) with 487424K/36864K bytes of memory.
*1 CISCO1921/K9 xxxxxxxx
Host7#sh inventory | in HWIC-1T
PID: HWIC-1T , VID: V02 , SN: FOCxxxxxxxxx
res
Paul
