wildcard mask question
arianto.wibowo
Just a little confuse about wildcard mask.
There are two questions, but the same point about WM.
  • if we want to allow IP 10.1.1.1, 10.1.100.1, and 10.1.120.1 to ospf routing, how it should be ?
          someone says : network 10.1.1.1 0.0.255.0 area 0, and the other says : network 10.1.1.1 0.0.255.255 area 0
          I thought WM 0.0.255.0 is not valid one so I assume that WM 0.0.255.255 is the right one.
  • if I want to allow 192.168.1.1, .2, .3, .16, .17, .18, and .19 using ACL, how should I config this ?
          is it true using WM 0.0.0.19 ?? I think it's not valid because 19 (0001011) is not contigues bit checking.
Need some explanation from you guys.
Thanks and regards,
Arianto W
Jon Marshall
Thanks and regards,
Arianto W
Arianto
0.0.255.0 is a valid wildcard mask. Wildcard masks do not have to be contiguous as subnet masks do.
0.0.255.0  means ->  exact match first octet, exact match second octet, can be anything in 3rd octet, exact match 4th octet
so the correct answer to above is  for 10.1.1.1, 10.1.100.1 and 10.1.120.1 a wildcard mask of 0.0.255.0 would be the correct one ie.
first octet must be 10
2nd octet must be 1
3rd octet can be any value from 0 -> 255
4th octet must be 1
note that with 0.0.255.0 wildcard mask it doesn't just include those 3 networks, it actually covers
10.1.0.1  -> 10.1.255.1
As for your second question - what 192.168.1.x range do you want to specify ie. 192.168.1.1 -> 19 or just the specific IPs listed above ?
Jon
Ganesh Hariharan
Hi Arianto,
A wildcard mask is necessary because OSPF supports CIDR and VLSM,unlike RIPv1 and IGRP.
so if you see the belwo example you will clear with your query!!
RouterA(config-router)#network 192.168.1.0 0.0.0.255 area 0
this will enable OSPF on all the interfaces whose ip address's fall in between 192.168.1.0-255
RouterA(config-router)#network 192.168.1.1 0.0.0.0 area 0
This will enable OSPF only on this specific Interface 192.168.1.1
Hope this clears out your query !!
If helpful do rate the valuable post.
Ganesh.H
Jon Marshall
Thanks and regards,
Arianto W
Arianto
2nd octet must be 1
4th octet must be 1
Jon
Only the specific that I listed.
But i got your point now.
And for 2nd question IPs : 192.168.1.1, 192.168.1.2, 192.168.1.3, 192.168.1.16, 192.168.1.17, 192.168.1.18, 192.168.1.19
Is it could be like this ?
192.168.1.1       00000001
192.168.1.2       00000010
192.168.1.3       00000011
192.168.1.16     00010000
192.168.1.17     00010001
192.168.1.18     00010010
192.168.1.19     00010011
last octet that changed are 4th, 7th, 8th
so WM is 00010011 = 19, its mean 0.0.0.19
Did my explanation correct ?
thanks.
You could understand it that way.
jerry
