wildcard masks
carl_townshend
Hi all, can anyone tell me how we work out what the wildcard mask is ?
cheers
royalblues
Level 10
Level 10
A simple method would be to subtract the subnet mask from 255.255.255.255
eg. if you need to know the wildcard mask for 255.255.255.240 then you can do
255.255.255.255 - 255.255.255.240 = 0.0.0.15
HTH, rate if it does
Narayan
mohammedmahmoud
Level 11
Level 11
hi Carl,
Wildcard mask is a bit matcher which is the inverse logic of the subnet mask (a subnet mask of 255.255.255.252 corresponds to a wildcard of 0.0.0.3, just inverse the binary 1s to 0s and vice versa) -> 0 = match and 1 = ignore, accordingly a wildcard of 0.0.0.0 = host, since all bits must match , and 255.255.255.255 = any, since we don't care what any bit is.
HTH,
Mohammed Mahmoud.
The wildcard mask is an "inverse mask", that is: bit 0 means "care" and bit 1 means "don't care".
An example of application is an access list:
access-list 100 deny 192.168.1.0 0.0.0.15
Conversion in binary
0.0.0.15 -> 00000000.00000000.00000000.00001111
192.168.1.0 -> 11000000.10101000.00000001.0000000
The interval of denied addresses is:
From 11000000.10101000.00000001.00000000 to 11000000.10101000.00000001.00001111
In decimal
From 192.168.1.0 to 192.168.1.15
That is all addresses from 192.168.1.0 to 192.168.1.15 are denied.
I hope this helps.
Best regards.
Massimiliano.
