Will Cisco WS-C2960X-24TD-L supports 1G SFP module. If yes kindly provide the part number..
Will Cisco WS-C2960X-24TD-L series supports 1G SFP module. Switch is actually showing SPF+ port and i need to connect 1G uplink from remote Dlink Switch....
Koh Chin Han
WS-C2960X-24TD-L
GLC-BX-D
GLC-BX-U
GLC-LH-SMD
GLC-SX-MMD
GLC-EX-SMD1
GLC-ZX-SMD
GLC-T
GLC-ZX-SM
GLC-LH-SM
GLC-SX-MM
CWDM-SFP
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/GE_Tx_Matrix.html
Reza Sharifi
Correct, this switch has 2 10Gig uplinks only (SFP+).  If you need to connect via 1Gig (SFP) you need need a different model.
see table-23 in this link:
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/data_sheet_c78-728232.html
