will STP reconverge when uplinkfast/Backbonefast is enabled ?
Can anyone confirms with a tested proof, If  STP reconverge when uplinkfast/Backbonefast is enabled ?
SPanning tree mode being used is Rapid PVST.
lgijssel
Level 9
Level 9
You should not use Uplinkfast/Backbonefast with RSTP. Both are improvements which are only valid for the older PVST+.
They have no functionality with RSTP and may cause adverse effects. Please turn them off.
You may check the technology page at:
http://www.cisco.com/en/US/tech/tk389/tk621/tk845/tsd_technology_support_sub-protocol_home.html
It states:
Rapid Spanning Tree Protocol (RSTP) is an evolution of the Spanning Tree Protocol (802.1D standard) and provides for faster spanning tree convergence after a topology change. The standard also includes features equivalent to Cisco PortFast, UplinkFast and BackboneFast for faster network reconvergence.
regards,
Leo
