02-23-2012 12:21 PM - edited 03-07-2019 05:08 AM
I am working on a backup system for my WAN. Verizon quoted the HWIC-3G-CDMA-V to work with my Cisco 1721 router. I have a bunch on these routers on a shelf and thought I would use them for the 3G network. Looking at the Cisco web site it does not list the 1721 as being able to work with this HWIC. I thought it might not be listed as the 1700 series are End of life. Does anyone know whether it will work?
Solved! Go to Solution.
02-23-2012 12:34 PM
Hey Phillip,
From this link, it looks they are not compatible.
Pronoy
02-23-2012 01:09 PM
Physically it WILL NOT fit into the slot of the 1721 router because the pins at the back do not match.
02-23-2012 12:34 PM
Hey Phillip,
Pronoy
02-23-2012 01:09 PM
02-23-2012 07:34 PM
Thanks for the rating Phillip.
