wipe a cisco 3132Q clean after it has been configured
burkins01
We purchase large amounts of the 3132Q switches for our customer contract.  On occasion, it is necessary to wipe a switch clean after it has
been configured for a cancelled order. Up to now, the customer has done the wipe, to use the switch with a new order.
They prefer I do it in house....is there a tutorial available here with a process to wipe a switch clean?
Hi Jim,
I've moved your post for our Network Infrastructure team to review and address your question.
Cheers,
Cerhi
Mark Malone
  Command or Action Purpose
Step 1 write erase [boot | debug]
Example:
switch# write erase
Warning: This command will erase the startup-configuration.
Do you wish to proceed anyway? (y/n)  [n] y
Erases configurations in persistent memory. The default action erases the startup configuration.
The boot option erases the boot variable definitions and the IPv4 configuration on the mgmt0 interface.
The debug option erases the debugging configuration.
Note
The running configuration file is not affected by this command.
