Wired 802.1X
I try this lab https://packetlife.net/blog/2008/aug/06/simple-wired-8021x-lab on WS-C2960L-48PS-LL but it has no
radius-server host
command, how should I do?
Cisco IOS Software, C2960L Software (C2960L-UNIVERSALK9-M), Version 15.2(5c)E, RELEASE SOFTWARE (fc1)
Thank you very much.
13 Replies 13
pieterh
syntax may have changed for your operational IOS version compared to the published document
it is radius server ... (without the dash "-")
Consolidated Platform Command Reference, Cisco IOS Release 15.2(7)E (Catalyst 2960-L Switches) - Security [Cisco Catalyst 2960-L Series Switches] - Cisco
Could I implement on access port to another vendor switch?
This question is not fully clear. Do you want to use another vendor switch that then should authenticate the attached computers, or do you want to attach another vendor switch to a cisco switch and authenticate that switch?
The first should work, if the vendor switch supports 802.1x. If it doesn't support it, then some cisco switches support that too, I think it's called "multi-host" mode.
I want to use another vendor switch that then should authenticate the attached computers, but I configured like this the interface was 'error-disabled'.
interface GigabitEthernet0/36
 description link to another vendor switch
 switchport access vlan 100
 switchport mode access
 authentication port-control auto
 dot1x pae authenticator
end
Ok, so if your other switch can do 802.1x authentication, then disable it for the uplink port on the Cisco switch. Unless you want to authenticate the Cisco switch itself.
Another vendor switch doesn't support, how should I do?
With another vendor switch you are mostly out of luck. There are some ways, but you can authenticate the port with the first client that connects to the other vendor switch. Downside, all other clients on that foreign switch will come into the same VLAN and are also all authenticated. This can cause various problems though and I don't recommend it.
Regarding the Catalyst 1000, it should support it, here is the guide for it:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst1000/software/releases/15_2_7_e/configuration_guides/sec/b_1527e_security_c1000_cg/configuring_radius.html
ah, I forgot 'aaa new-model' command.
Then how to verify connection to the radius? and which windows authentication method should I use?
This basically all depends on your Radius server and what authentication type you want to use. Please read up first about the different types (username+password, user or device certificate, combination, just Windows domain membership, .....).
Depending on your business needs, you need to configure the right one for you and configure this at the Radius server and then the client.
If the other vendor switch should do the authentication, disable authentication on this listed port.
What about the C1000-24T-4G-L, I see the datasheet says it support here https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-1000-series-switches/nb-06-cat1k-ser-switch-ds-cte-en.html. However, It has no 'radius' command, how should I do?
you should be able to use a dumb (non-manageble) switch,
but then you need to add MAB as authentication method on the port to authenticate the mac-address of this switches uplink
after that you can use the multi-host mode as suggested by  patoberli to auth all clients with DOT1x supplicant connected to this dumb switch, auth is done by the 2960, not the dumb switch
