Wireless LAN Controller 2100 series
coast2000
I have a Wireless LAN Controller 2100 series running software version 6.0.182.0 (capture) on VLAN 25(192.168.25.1)
but it's not allowing web login from VLAN 1(192.168.1.21).
I can ping the IP from VLAN 1 and I can reach it on the web (image 1). but when I click proceed, an error comes up (image2)
The same configuration and same VLAN on another  Wireless LAN Controller 2100 series device running software version 7.0 allow the connection when I click proceed.
Any advice, please?
thanks,
6 Replies 6
kapydan88
Level 4
Level 4
Hello.
Did you try https for login to this wlc or another browser (opera, ie, mozilla etc)?
yes, I did. on internet explorer, chrome, chromium and edge.
same error page on all browser
Can you connect to this wlc via cli (telnet or ssh via putty)? Maybe allowed only this way.
I can from the same VLAN, but doesn't allow from another VLAN. there was a suggestion that it has to do with ACL configuration.
Leo Laohoo
Is HTTP/HTTPS disabled?
HTTP is disabled while https is enabled. but I can reach from the same VLAN just not from another VLAN.
