Telnet drops connection after enter
Fenderbridge
I have a router that I am telnetting into via raspberry pi.  Works perfectly fine on switches, but on the two 1921 routers, after hitting enter more than twice, or getting a log message, the connection gets dropped.
"2001" is an alias for "telnet 127.0.0.1 2001", where 2001 is the port number.
@raspberrypi:~$ 2001
Trying 127.0.0.1...
Connected to 127.0.0.1.
Escape character is '^]'.
ser2net port 2001 device /dev/ttyUSB0 [9600 N81] (Debian GNU/Linux)
RouterA>
RouterA>
RouterAConnection closed by foreign host.
Me@raspberrypi:~$
Any ideas?  Thanks!
Fenderbridge
Well, I'm not sure why, I'm not entirely sure how, but the problem appeared to be that particular serial connection.  After moving it to another one of the Gearmo's 3 ports and on a different USB port, it started working normally.
I'm just going to call it a win, and use a different port for the router.
Thanks for your help, folks!
9 Replies 9
balaji.bandi
You already logged in to Router by below prompt :
RouterA>
I am thinking becuase there is no inputs - it time out and closed the connection.
can you post router config here?
BB
Yes, sir, I do connect, and when i immediately hit enter, it disconnects.
This is as far as i could get over telnet
Me@raspberrypi:~$ 2001
Trying 127.0.0.1...
RouterA>en
Password:
RouterA#sho run
Building confiConnection closed by foreign host.
Me@raspberrypi:~$
I'll try and grab the configs when i get a chance to be physically available to them
Hello @Fenderbridge ,
according to the following ouput:
Trying 127.0.0.1...
You are using the rasberry pi as a terminal server by making telnet to 127.0.0.1 TCP port 2001, but actually you are using a USB to serial console cable to connect to RouterA.
The issues are likely related to some settings on device /dev/ttyUSB0.
This explains why you are able to reach the router prompt even if only SSH is allowed on the router vty lines as noted by @joelm .
Edit:
you are actually attempting to connect to router console not via telnet and when you use your laptop as console connection it works fine
Hope to help
Giuseppe
Instead of using telnet, I connected my laptop directly to the console instead of going through raspberry pi telnet, got in no problem.
Building configuration...
*Jun 15 01:55:05.723: %SYS-5-CONFIG_I: Configured from console by console
Current configuration : 1454 bytes
! Last configuration change at 01:55:05 UTC Mon Jun 15 2020
version 15.7
service password-encryption
hostname RouterA
boot-start-marker
boot-end-marker
enable password 7 [password]
aaa new-model
aaa session-id common
no ip domain lookup
ip domain name mydomain.com
ip cef
no ipv6 cef
license udi pid CISCO1921/K9 sn FTX17238341
username me password 7 [password]
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 172.16.0.1 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/0/0
no ip address
interface FastEthernet0/0/1
no ip address
interface FastEthernet0/0/2
no ip address
interface FastEthernet0/0/3
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip ssh version 2
control-plane
line con 0
logging synchronous
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
logging synchronous
transport input ssh
scheduler allocate 20000 1000
end
line 2
 no exec
 stopbits 1
line vty 0 4
 logging synchronous
 transport input ssh
You're coming in on line 1, right?  If so, the transport input is set to ssh only.  Try changing that line to transport input telnet or transport input all
You should also strongly consider using SSH instead of telnet so the traffic is encrypted.
I am coming in through line console 0.
Here's my setup.
Laptop > ssh or vnc to Raspberry pi > gearmo usb to 4-port serial > routers and switches
My RPi is set up to telnet through the usb to serial.
Thing is, I can connect just fine to the switch 3750, but not the router 1921.
Leo Laohoo
Duplicate IP address
Not sure that ip address matters if I am directly connected via console cable.
Not to menti9n, i move the console cable over to the switch and there is no problem at all!
Fenderbridge
