wireless
Anuj Singhi
Level 3
Level 3
Can anybody tell me if AIR-CT2504-K9 support Guest-LAN?
Platform Support
Wired guest access is supported on these platforms:
Cisco WLC 4402, 4404, WiSM, 3750G, 5508, WiSM2, Virtual WLC
for configuration and references check the following links
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/99470-config-wiredguest-00.html
**********DO rate helpful posts*************
Leo Laohoo
Yes.  There are several ways of doing guest wireless.
That I know, I want to know if this model controller can support Guest-LAN?
Platform Support
