Wireshark Analysis
Pls find the capture of Wireshark
Soruce:10.190.190.170
Destination:199.255.140.136
Websense IP: 10.190.147.28
We have webfiltering server(websense), So Any traffic which going to Internet it will be filtered via websense, We are suspecting some issue in Websense, but not able to get any relevant details from the capture
Can anybody help
Urgent help will be highly appreciated
Br/Subhojit
6 Replies 6
devils_advocate
Level 7
Level 7
You have not said what the actual issue is?
What are the symptoms?
Can you diagram your setup?
Our actual issue is for some of the Inteent Url page can't be displayed error is coming, But when we are using this url from Other location/Public Interent it is working
We are suspecting som issue in websense
Setup
User--Access switch--core switch--Juniper Internal Fw--DMZ Segment--ASA Firewall-- Interent Switch--Internet Router--ISP Cloud
Relevant Policy in Firewall & routing already present
Br/Subhojit
According to the Wireshark capture, something on the device is missing up the checksums. TCP checksums are incorrect.
The packets are received by the host (as can be seen in Wireshark), but they never reach the Destination (199.255.140.136) as the TCP checksums are incorrect.
Berta.
Not able to get you, Where to check tcp checksum is having problme / on deivce or Firewall
Br/Subhojit
Tcp checksum could be on device or firewall, you need to check both of them. If the problem happens in any device of your network seems the checksum is falling on firewall.
Berta.
In that case, Can you pls share how to check tcp checksum in asa fireall / command & iptions
br/Subhojit
