Wr mem fails on C6K
e.hoehn
C6500-SUP720-3B#wr
%No memory available: Update of NVRAM config failed!
has anyone a explanation ? the Configuration is not that big it should definitly fit into the NVRAM, but the box is low on Memory :
Processor Pool Total: 391036432 Used: 366100000 Free: 24936432
I/O Pool Total: 67108864 Used: 10437776 Free: 56671088
Giuseppe Larosa
Hello Emanuael,
check with sh users
if there are other vty sessions open
there might be a sh conf pending on some other vty.
the show proc mem doesn't show the amount of memory in filesystem nvram:
do
dir nvram:
example from a C6500 with sup720B
dir nvram:
Directory of nvram:/
1918 -rw- 149823 startup-config
1919 ---- 24 private-config
1920 -rw- 149823 underlying-config
1 ---- 4 rf_cold_starts
2 ---- 47 persistent-data
3 -rw- 0 ifIndex-table
1964024 bytes total (1811053 bytes free)
Hope to help
Giuseppe
nsn-amagruder
Level 5
Level 5
service compress-config may help if the last suggestion show the config in NVRAM is large or almosted used.
Hello Guys,
Thanks for the responds, but it actually does ont help ...
here the output (and as I sayed, the config is not that larg ...)
C6K-SUP720-3B#dir nvram:
1918 -rw- 29322 startup-config
1919 ---- 7175 private-config
1920 -rw- 29322 underlying-config
2 ---- 49 persistent-data
3 -rw- 3460 ifIndex-table
1964024 bytes total (1921331 bytes free)
C6K-SUP720-3B#sh conf | i Using
Using 29322 out of 1964024 bytes
Does anyone has other suggestions ?
