write erase doesn't erase sh run
robertkwild
Hi all,
I've done a
wr erase
After that did a
reload
Asks me to reload so press enter and then it reloads all stacks
Initial configuration dialog - I press no
Auto install - I press no
Then I run command "sh run" and I expect to see no configs but I do
also when running command "sh switch" the switches in the stack still hold the same priority
Am I missing something
Rob
10 Replies 10
pman
Is the stack cable still connected? check it.
also use this:
no switch <stack-member-number> provision
If you remove a provisioned switch from the switch stack, the configuration associated with the removed stack member remains in the running configuration as provisioned information. To completely remove the configuration
Reza Sharifi
Make sure your config register is 0x2102 before reloading.
So I reload to config 2102 and then if I do wr erase it will work, even if all switches still in stack
Before you do anything, make sure your config register is 0x2102
If it is not, change it to 0x2102, erase the config for the whole stack from the master switch and then reload the entire stack.
how do i go into 0x2102
show version should show you the current config register.
If you need to change it follow this:
config t
config-register 0x2102
exit
wr
Verify with "show version" It should say that after the next reboot the config register will be 2102
Now you can erase the config and reload the stack.
ok cool thanks @Reza Sharifi and after im in2102 do i need to go back into the other config register i was in before or not?
ok i did what you said @Reza Sharifi and when it reloads and comes back the config reg is still 0x102
In the original post Rob says " I run command "sh run" and I expect to see no configs" Am I correct in assuming that this means that he expects an absolutely empty config? That is not how it works. Even with no user configuration there are certain things (like interface names and default configurations) that show up in the "empty" config.
Rick
Leo Laohoo
Yes, there is.
Even a switch, fresh from the box, will have default config.  I believe this is what you are seeing, the default config.
