Write erase on VSS 6500
michaelvd123
Dear all,
I have a functional VSS with VSL well configured and so on.
I need to completely review its configuration and startup again remotely via a technician.
If I perform a write erase on it, will it destroy it's VSS configuration (VSL ports at most)?
Should I put in my new configuration the VSL ports back again?
Best regards,
Mark Malone
Hi erase will wipe everything except the vtp and vlan database , so you will have to reconfigure it if you do that
