wrong data sent by SNMP
testmark808
Community Member
Hello there
I'm using 93180-FX3 chassis cisco switches and my NXOS is 9.3(9)
I have connected SNMP of switch to my zabbix server. but there is a bug in SNMP data that is being sent. many spikes happen with the number of rx byte of every port. for example, in time t0 data of SNMP is 5Gbps, in t1 it is 10Tbps and again in t2 it will return to 5Gbps. while 5Gbps is correct and my port's capacity is 10Gbps and it is impossible to see 10Tbps traffic on it. so it is definitely a bug in NXOS.
has anybody faced with the same problem? did cisco patch this bug in later versions of NXOS
thanks a lot
Mark Elsen
  - Verify if  this is a real bug by looking at port counters too , at intervals  when the spikes are happening ,
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
unfortunately, I never could catch this bug in port-counters. it seems like it is generated by accident and watching port counters would be exhausting. but we would do our best and try to find it. if we catch this problem on port counter, I will report it here
are this port is member of portchannel ?
Yes, It's a member of port-channel.
