Wrong [Mode] button push?
Teakin_Batrune
Community Member
I held the mode button wile powering on, until everything stopped blinking. Now the SYST light just keeps blinking. It looks like a pattern, but I don't seem to be able to discern it.
Catalyst 3560 series PoE-48
WS-C3560-48PS-S V07
Just got it last night, used.
This is the first time I've used a real switch. I've played with DD-WRT and pfSense, but not much.
I guess I should also state that the reason for doing this... As I said, it's used, I can't get into it. Tried 10.0.0.1 and 10.0.207.208 that's on the label on the top.
11 Replies 11
acampbell
What are you seeing on a terminal connected to the console port ?
Alex
Regards, Alex. Please rate useful posts.
Found the RJ45-DB9 cable, at used computer shop across town. Now to pull out an old laptop that has a serial port.
Is there a way to Ethernet into the console port?
You should have got a console cable along with the switch, what is the output you get on console terminal ?
I also suggest you to read this link which helps you to get started http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3560/hardware/quick/guide/3560gsg_08.html
Thanks & Regards,
        Swamy
Well, that would be nice, however I got it used... They don't always have all the parts.  My friends had the cable.
I just posted the output to acampbell. Now I have to find out how to hack it, and wipe it.
Catalyst 3560 Switch Getting Started Guide has lots of good stuff, but it dose not cover everything.
Thats nice to hear the document helped you, it is just to get started. If you looking for more details should go through the configuration guides http://www.cisco.com/c/en/us/support/switches/catalyst-3560-series-switches/products-configuration-examples-list.html.
Thanks & Regards,
        Swamy
                                  NOTICE TO USERS
This is an official computer system and is the property of the
St. Anthony's Hospital. It is for authorized  users only. Unauthorized
users are prohibited. Users (authorized or unauthorized) have no explicit
or implicit expectation of privacy. Any or all uses of this system may be
subject to one or more of the following actions: interception, monitoring,
recording, auditing, inspection and disclosing to security personnel and
law enforcement personnel, as well as authorized officials of other agencies,
both domestic and foreign. By using this system, the user consents to these
actions. Unauthorized or improper use of this system may result in
administrative disciplinary action and civil and criminal penalties. By
accessing this system you indicate your awareness of and consent to these
terms and conditions of use. Discontinue access immediately if you do not
agree to the conditions stated in this notice.
User Access Verification
Username:
So you can view the console terminal. Are you able to login with username and password ?
Thanks & Regards,
        Swamy
No, but I was able to reset it. "The switch now behaves like an unconfigured switch"
I'm trying to do Express Setup now. I don't see a guide on how to do set up in Terminal.
...Aaaannnnnd it still has the user/password from the last owner.
Can I get a download of someones brain that knows iOS?
You will have to do a password recovery, find the steps in this document http://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/12040-pswdrec-2900xl.html
Thanks & Regards,
        Swamy
Teakin_Batrune
Community Member
If ether of you feel like being nice, could use more (basic) help
https://supportforums.cisco.com/discussion/13056766/getting-started-ws-c3560-48ps#comment-11456336
