WRONG SYN,ACK SEQ Number
Hi Guys,
I have been investigating an issue for a month now and still can't figure out what the issue is.
Basically we have clients connecting to a server on port 80 but 1% of the connections fail due to a socket error. The packet traverses as below
Client - firewall - ipsec tunnel - firewall - loadbalancer - server
When we do a TCP dump between the firewall and loadbalancer we can see the successfull connections which follows the normal 3 way handshake as expected but when we look at the failed transactions we are seeing the follwing
SYN SEQ(lets say 1000000)
[TCP ACKed unseen segment]SYN,ACK SEQ(totally random number 124124) ACK(totally random number + 1 - 124125)
[TCP Spurious Retransmission] SYN SEQ(1000000)
[TCP ACKed unseen segment]SYN,ACK SEQ(t124124) ACK(124125)
And so on until the packet is dropped.. So it seems either the LB or the server is sending the WRONG SYN,ACK SEQ number?? I checked previous TCP streams and also filtered on this wrong SEQ number and can't find it anywhere in my capture so its not something that was stuck in a previous segment or so. I can also confirm I have no packets missing from my wireshark.
The issue is totally random during the day and not a load or busy period issue.
From what I can see and read on the internet the LB might be involved with this 3 way handshake even though one would expect this to be between the server and the client.
I can't do a capture between the server and the LB due to the server being a VM that sits on a host on a different switch where I dont have access to atm. Also the LB Logs doesn't show any issues.
Greetings,
The LB can be configured to act as proxy for TCP connections so that clients connect to the LB with 3-way handshake and then LB connects to server with a different socket. (This can even be an already open socket being reused.)
You could check the LB configuration but it's hard to misconfigure a single server for TCP proxy and not the others if they are in the same server farm.
Do you have a lot of servers behind the LB for this service? This may but only a specific server having the issue only some of the time. This could explain the 1%.
If you have permission and sufficient capacity you can disable servers one at a time on the LB to see if the issue remains or not.
If it does than I'd focus on the LB more. If it goes away with a certain server then look at that specific server.
Hope this helps.
JF
