WS-3550-48-SMI upgrade
nelsonm
I am planning on upgarding some old code on 4 WS-3550-48-SMI switches.
I was planning on using:
Release 12.2.44-SE6
Filename c3550-ipbasek9-tar.122-44.SE6.tar (16 MB Flash reqiured)
It appears the flash only has 15.25 MB of RAM which can't be right??
Switch01#sho flash
Directory of flash:/
2 -rwx 0 Jan 01 1970 00:01:26 env_vars
3 -rwx 342 Jan 01 1970 00:01:26 system_env_vars
5 -rwx 3911 Dec 17 1994 18:14:43 config.text
9 drwx 192 Mar 01 1993 00:03:24 c3550-i9q3l2-mz.121-9.EA1c
15998976 bytes total (11633152 bytes free)
Switch01#
Am I miscalulating??
Switch01#sho ver
IOS (tm) C3550 Software (C3550-I9Q3L2-M), Version 12.1(9)EA1c, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Tue 28-May-02 10:06 by antonino
Image text-base: 0x00003000, data-base: 0x004E4568
ROM: Bootstrap program is C3550 boot loader
PJAX_Switch01 uptime is 2 years, 4 weeks, 2 days, 4 hours, 35 minutes
System image file is "flash:c3550-i9q3l2-mz.121-9.EA1c/c3550-i9q3l2-mz.121-9.EA1
c.bin"
cisco WS-C3550-48 (PowerPC) processor (revision E0) with 65526K/8192K bytes of m
emory.
Processor board ID *****
Last reset from warm-reset
Running Layer2 Switching Only Image
Ethernet-controller 1 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 2 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 3 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 4 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 5 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 6 has 1 Gigabit Ethernet/IEEE 802.3 interface
48 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
The password-recovery mechanism is enabled.
384K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0A:F4:1F:45:80
Motherboard assembly number: 73-5701-06
Power supply part number: 34-0967-01
Motherboard serial number: *****
Power supply serial number: DCA06351VJ3
Model revision number: E0
Motherboard revision number: D0
Model number: WS-C3550-48-SMI
System serial number: *****
Configuration register is 0x10F
Switch01#
Any issues/problem with upgrading this?
Any input would be appreciated.
Thanks in advance!!
kplunkett512
Flash Memory
All 3550s have 16 MB of internal Flash memory. The Flash memory is not upgradeable.
There is a limit to the number of images that you can store in Flash. Always check the size, in bytes, of the image in the LAN Switches section of Downloads - Switches ( registered customers only) before you upgrade software. Issue the dir flash: command in order to compare the size of this image with the free space in Flash.
Attached is a link for additional reference:
http://www.cisco.com/en/US/products/hw/switches/ps646/products_configuration_example09186a0080169623.shtml
kplunkett512
Flash Memory
Thanks for the input! Link is very helpful!
