WS-4506-E Manage by Web mode.
anas.awad
Hello Everyone,
I'm trying to manage the switch through the GUI based application. is it possible?
its not working as attached.
karthikbe40
You can configure in GUI mode also..
for this you need the cisco CatOS IOS image with .cv (cisco view) image file in flash memory.
Check the below command..
switch# dir bootflash:
cat4000 (enable) dir bootflash:
-#- -length- -----date/time------ name
  1  3651336 May 16 2001 14:30:39 cat4000.5-5-8.bin
  2  2580656 Oct 09 2001 11:22:20 cat4000-cv.5-5-8.bin
9365320 bytes available (6232248 bytes used)
cat4000 (enable)
It shows two image file means, you just need to enable http server command in 4506-E switch.
set ip http server enable
set ip http port 2398 (use 2398 instead of usual port no.80
set ip http port default
If two images are not displayed..you need to download the image file from cisco website.
Karthik
Hi Karthik,
Thank you for replay.
so i guess upgrading is mandatory??
as below is the current image
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch  Software (cat4500es8-UNIVERSALK9-M), Version 03.07.00.E RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Sun 07-Dec-14 17:59 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2014 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 15.1(1r)SG5
TheGate-Core-SW uptime is 21 weeks, 1 hour, 49 minutes
Uptime for this control processor is 21 weeks, 1 hour, 51 minutes
System restarted at 09:44:45 UTC Mon May 23 2016
System image file is "bootflash:cat4500es8-universalk9.SPA.03.07.00.E.152-3.E.bin"
Jawa Revision 3, RadTrooper Revision 0x0.0x41, Conan Revision 0x1B9E
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Information for 'WS-X45-SUP8-E'
    License Level: entservices   Type: Permanent Right-To-Use
    Next reboot license Level: entservices
cisco WS-C4506-E (P5040) processor (revision 2) with 4194304K bytes of physical memory.
Processor board ID FXS1849Q089
P5040 CPU at 2.2GHz, Supervisor 8-E
Last reset from PowerUp
30 Virtual Ethernet interfaces
288 Gigabit Ethernet interfaces
40 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
