WS-4510R+E VSS Quad Supervisor (Sup 8-E)
Rss
I have a Sup-8E in stock, but I want to use in my VSS 4507 chassis active-standby.
Does anybody knows if it is possible to use active chassis with two Sup 8-E and the standby chassis with only one?, some kind of VSS quad Supervisor but with only 3 supervisors?
Thanks for your help.
acampbell
Looking at the config guide for IOS/XE 3.6.0
QUAD supervisors ARE supported
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/XE3-6-0E/15-22E/configuration/guide/xe-360-config.html
Then in the VSS section.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/XE3-6-0E/15-22E/configuration/guide/xe-360-config/vss.html#85440
I suggest you look for the correct config guide for your IOS/XE and read thoroughly
INDEX:-
http://www.cisco.com/c/en/us/support/switches/catalyst-4500-series-switches/products-installation-and-configuration-guides-list.html
Alex
Regards, Alex. Please rate useful posts.
