10-05-2007 10:04 AM - edited 03-05-2019 06:55 PM
I have cisco sup2 & i need to put gig card 10/100/1000 WS-6548-GE-TX or WS-6148-GE-TX.
Pls suggest CATOS for SUP-2.
Please help it is very urgent.
10-05-2007 10:09 AM
Hi Moorthy,
WS-6148-GE-TX need minimum 7.6(1) and WS-6548-GE-TX also need minimum 7.6(1)
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/relnotes/ol_4498.htm
Ankur
*Pls rate all helpfull post
10-05-2007 10:34 AM
10-05-2007 11:03 AM
You need to upgrade your catos software to 7.6.1. Your current version does not support it.
10-05-2007 11:38 AM
Thanks for your reply kindly suggext the CATOS Software size so that it can store in current mem.
If you can send the document for how to upgrade the CATOS in switch it will be helpful.
moorthy.
10-05-2007 09:35 PM
Hi Moorty,
Your sup engine have 32M flash and 128 MB DRAM which will fully support 7.x train CATOS. Your bootstrap version also support 7.x train of CATOS so you are good to go.
You can view this link which will guide you DRAM,Flash and boot rom requirement for 7.x release
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/relnotes/ol_1982.htm#wp201331
Also this link will guide you to upgrade your CATOS
http://www.cisco.com/warp/public/473/161.html#maintask1
Ankur
