WS-C2924m-XL Vlan speed configuration?
chris6273
Hi guys,
I have been wondering this for a while but I could not find any references to this on Google so here goes...
Is it possible to configure Vlan speed on the WS-C2924m-XL switch?
Eg. If I have 5 Vlans sharing 1 100Mbps port to an uncontented switch, is there anyway I can restrict each Vlan to have only 20Mbps capacity each?
Thanks for your answers
Eugene Lau
Hey Chris,
As the 2924M-XL was an early model IOS switch, the QoS Functions were quite limited.
See:
http://www.cisco.com/en/US/products/hw/switches/ps607/products_qanda_item09186a0080116ffe.shtml#q1
(contact web-help@cisco.com if you find that you are unable to access links).
In summary, it pretty much only supported 802.1q and CoS. No rate-limiting capability.
HTH somewhat.
Eugene
