LACP Port-Channel with Checkpoint Firewall
richi3161
we have build up a Port-Channel to a Checkpoint Firewall, which is running a new software, which allows this the first time.
Before it was not possible.
Now we have two Cisco 6500 Series Switche form where each Port-Channel was built to two Checkpoint maschines.
One Port-Channel worked, one not.
We found out, that we need at minimum the IOS installed: 12.2(33 SXI3 to run LACP successfully with Checkpoint.
Is this known, that IOS version has an influence on LACP?
Or was there a bug?
Reza Sharifi
Hi Richi,
LACP has been supported in earlier versions of SXI releases like SXI1, SXI2, etc...
Reza
Reza Sharifi
Hi Richi,
Reza
before we had the IOS s72033-adventerprisek9_wan-mz.122-18.SXF11.bin active.
Looks like this.
Thanks!
