WS-C2950G-24-EI is EOL,which is the best replacement switch.
shricisco
Hi Mate,
That part number is gone end of life while back.EOL announcements usually suggest a replacement part number. for your part number you can see it  here .however the product suggested have gone EOL as well.
as a close replacement, you can consider 2960-X series and you can find some additional information from links below
https://www.cisco.com/c/dam/en/us/products/collateral/switches/catalyst-2960-x-series-switches/migrating-catalyst-2k.pdf
https://www.cisco.com/c/en/us/products/switches/catalyst-2960-x-series-switches/models-comparison.html
Prabath
***Please rate all the useful posts***
-Prabath
Leo Laohoo
2960X is probably the only replacement for the 2950-series switches.
