01-12-2015 12:28 AM - edited 03-07-2019 10:11 PM
Hi Team,
I recently purchased WS-C2960-24-S switch and I wanted to ask the following questions:
1. What is the difference between NVRAM, ROM, flash-simulated non-volatile and each additional memory type and how each memory type is defined on the system?
2. What is the logical (i.e. "bs","nvram") and psychical implementation of each memory type on the device board?
3. What is the "-p" flag of "boot" command on the boot loader used for and how can I access the JTAG on the board?
4. To which memory does the boot loader loads the firmware to?
5. Is there a detailed datasheet which describes the board components?
6. Where does the boot loader environment variables are saved?
Thanks.
01-13-2015 03:07 PM
hi rnd9xkdjsma, do you have a smartnet contract when you bought this device? TAC would be able to help with this if you purchased that with the device.
02-04-2015 04:36 AM
Thanks Ferdinand.
I now do have a smartnet contract.
Thanks.
