ws-c2960 gui
alexispino
I need to enable the GUI interface of a switch 2960 but only with user privileges read-only and I have not always been as privileged user requests 15
how I can enable read-only interface gui
thank
Nagaraja Thanthry
Unfortunately, there does not seem like a way to enable read-only access for
the GUI on the switch. Both regular web GUI as well as CNA require level_15
access. You could try TACACS based command authorization and see if that
helps.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/1
2.1_19_ea1/configuration/guide/swauthen.html#wp1036936
Hope this helps.
NT
