03-07-2012 05:14 AM - edited 03-07-2019 05:24 AM
Can any body update me if Cisco WS-C2960C-12PC-L can be used to connect an IPTV. If Possible Kindly Provide me with a Reference.
Thanks and Regards
ZIYA
Solved! Go to Solution.
03-10-2012 12:38 AM
You mean multicast? Yes. Multicast support is briefly discussed in the Data Sheet.
03-07-2012 12:14 PM
You mean power up an IPTV using PoE ports? Depends on your IPTV power requirements. This model can only supply up to 10w of PoE.
03-09-2012 11:21 PM
Power is Provided externally through adaptors, I mean to say, does it support IPTV Protocols.
03-10-2012 12:03 AM
What exactly are the IPTV protocols? I mean the switch you mentioned is a Layer 2 switch. It can't distinguish any higher-level protocols.
03-10-2012 12:28 AM
This is an edge switch, we are planning to connect IPTV to this Switch, does it support IGMP
03-10-2012 12:38 AM
03-12-2012 11:00 PM
Got it, Thank you very much leo
03-13-2012 02:30 PM
Thanks.
