04-09-2015 09:55 AM - edited 03-07-2019 11:28 PM
Hi All,
I am currently using a switch
For connect two network between voip Cameras and workstation, So I configured SVI that act as a default gateway for both network and make them see each other.
But now, the management system want those network be reachable form the corp network and viceversa.
So I was thinking I can create a routing port on the switch, assign it an IP address and then create and ip route and send all the traffic for those network out of gi0/24. But I am not sure the switch has the capability to have this command. (I don't have access to the switch right now, but I want to be prepared.)
This is additional Info.
Video Network. 192.168.X.X
Workstation Network. 10.200.50.X
interface Vlan1
ip address 192.168.192.254 255.255.255.0 secondary
ip address 192.168.191.254 255.255.0.0
interface Vlan2
ip address 10.200.50.220 255.255.254.0
These are the network I have to reach.
10.15.22.51 255.255.254.0, 10.15.22.254
10.14.91.9 255.255.255.0, 10.14.91.254
10.14.90.9 255.255.255.0, 10.14.90.254
10.14.89.9 255.255.255.0, 10.14.89.254
10.14.93.8 255.255.255.0, 10.14.93.254
10.14.93.38 255.255.255.0, 10.14.93.254
I was thinking to create an IP route command for all those subnets, can someone tell me that is achievable with only static routing and, tell me I the 2960 switch can do that.
PFA the show run of the Cisco switch.
04-09-2015 12:38 PM
Hi Juan,
Please take a look at the config guide.
"Before enabling routing, enter the sdm prefer lanbase-routing global configuration command and reload the switch."
Also it does not support routing protocols.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_55_se/configuration/guide/scg_2960/swipstatrout.html#wp1202471
Hope this helps and kindly grade all useful posts.
Madhu
04-09-2015 12:40 PM
Another useful post can be seen below
https://supportforums.cisco.com/discussion/11047826/c2960-s-lan-base-and-lan-lite-static-routing
Hope this helps and grade all useful posts.
Madhu.
