05-31-2011 02:28 PM - edited 03-06-2019 05:17 PM
Hi all i just need to know if a ws-g5428 will work in a ws-c3508g-xl
i need to setup copper up link from a ws-c3508
i cant work out from the cisco site some doc"s say yes some say not supported
Solved! Go to Solution.
06-01-2011 03:01 PM
The matrix found in the link I've posted will tell you what is the minimum IOS but there's no harm in using the WC17 as there are more features compared to the old one. Please try to avoid using the XU.
06-01-2011 03:17 PM
Thanks for the ratings.
05-31-2011 02:41 PM
It's supported as long as you have the correct IOS.
Cisco Gigabit Ethernet Transceiver Modules Compatibility Matrix
05-31-2011 03:08 PM
Hi thanks for the reply what ISO should i install
thanks
06-01-2011 03:01 PM
06-01-2011 03:17 PM
06-02-2011 03:30 AM
just put iso wc-17 at lease it see them
00:00:21: %GBIC_1000BASET-6-GBIC_1000BASET_DEFAULT_CONFIG: 1000-BaseT GBIC module is detected in Gi0/1.
00:00:21: %GBIC_1000BASET-6-GBIC_1000BASET_DEFAULT_CONFIG: 1000-BaseT GBIC module is detected in Gi0/2.
00:00:21: %GBIC_1000BASET-6-GBIC_1000BASET_DEFAULT_CONFIG: 1000-BaseT GBIC module is detected in Gi0/3.
00:00:21: %GBIC_1000BASET-6-GBIC_1000BASET_DEFAULT_CONFIG: 1000-BaseT GBIC module is detected in Gi0/5.
all i need to do now work out how to get to work when i plug something in it wont come up
06-05-2011 09:33 PM
Hi all can someone point me to some white pages on how to config these interfaces so i can use a pc and linksys SD 2005 10/100/1000 in that port
i can only get to work if i plug a server in to it
08-13-2011 06:04 AM
fix it got a new switch
