WS C3560 48PS port issue
ctlhelpdesk
Hello all.
I have a c3560 that on Port 1 I can not get any device to talk to the DHCP server.
Previously there was a client connected to this port however over the weekend he stated he lost connectivity.
In my troubleshooting I have connected that client ot another port and now he is good to go...
I connected my laptop and tried to connect to the network however I could not.
I checked the logs and did not see anything that lead me to think it was having problems.
Checked the interface and it shows UP when a device is plugged into it.
I also did an Administrative shutdown on that interface and started it back up yet no luck.
As per above I did a shutdown command from Conf T on that interface and started it with a No Shut command.
Is there another way to shut this down and hopefully start it back up without having to restart the entire switch?
Do I have a bad port?
This switch is running SW Version 12.2(55)SE1 and SW Image C3560-IPSERVICESK9-M
Thanks Much ahead of time
Reza Sharifi
Jim,
What happens if you connect your laptop to this port and assign an IP to it.  Example your laptop 10.10.10.2/24 and the switch (make the port a routed port by issuing command "no switchport")10.10.10.1/24? Does the interface on the switch go to up and up? can you ping from PC to the switch and the other way around?
Jim,
  Have you tried restarting the switch? Make sure that the port is in the correct vlan and that it has all the proper commands.
   RG
Reza
Hi I am actually the person who started this thread and I appologize for the delayed response.
Ok I tried what you had suggested and yet that port will not allow me to connect to any internal or external resource.
One thing I have noticed is there are 2 vlans configured on this switch.
Vlan1 is for the management interface/ip address and Vlan2 is for the phones/PC network
Here is how port 1 and port 2 on vlan 2 are configured Note thaat port 1 is the issue in our case.
interface FastEthernet0/1
switchport voice vlan 2
mls qos trust device cisco-phone
spanning-tree portfast
interface FastEthernet0/2
In response to CityNational...no I have not restarted the switch and the reasoning for this is I guess I am affraid that if port 1 is acting silly I wouldn't want to replicate this on the others.
To add one thing I did notice is that port 1 even though it is in vlan 2 seems as if it can talk to only our Cisco Phone system which is in a total different IP address scheme.
I suppose I can reset the switch and cross my fingers that nothing more gets stupid.
Below is the running config of this switch (hope it fits)
CIN-OEM-IDF1-SWA#sho config
Using 7164 out of 524288 bytes
version 12.2
no service pad
service password-encryption
service sequence-numbers
hostname CIN-OEM-IDF1-SWA
boot-start-marker
boot-end-marker
logging buffered 12000
enable secret 5 $1$nP5n$OQd5SRYM1dG9DXo8sRmA50
no aaa new-model
clock timezone EST -5
system mtu routing 1500
vtp domain CTL
vtp mode transparent
no ip domain-lookup
mls qos
crypto pki trustpoint TP-self-signed-4129494400
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4129494400
revocation-check none
rsakeypair TP-self-signed-4129494400
crypto pki certificate chain TP-self-signed-4129494400
certificate self-signed 01 nvram:IOS-Self-Sig#3030.cer
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 2
name VOIP
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface FastEthernet0/25
interface FastEthernet0/26
interface FastEthernet0/27
interface FastEthernet0/28
interface FastEthernet0/29
interface FastEthernet0/30
interface FastEthernet0/31
interface FastEthernet0/32
interface FastEthernet0/33
interface FastEthernet0/34
interface FastEthernet0/35
interface FastEthernet0/36
interface FastEthernet0/37
interface FastEthernet0/38
interface FastEthernet0/39
interface FastEthernet0/40
interface FastEthernet0/41
interface FastEthernet0/42
interface FastEthernet0/43
interface FastEthernet0/44
description AP2
switchport mode trunk
speed 100
duplex full
interface FastEthernet0/45
interface FastEthernet0/46
speed 100
duplex full
interface FastEthernet0/47
switchport access vlan 2
interface FastEthernet0/48
interface GigabitEthernet0/1
mls qos trust dscp
interface GigabitEthernet0/2
mls qos trust dscp
interface GigabitEthernet0/3
mls qos trust dscp
interface GigabitEthernet0/4
mls qos trust dscp
interface Vlan1
ip address 192.168.2.26 255.255.0.0
interface Vlan2
no ip address
ip default-gateway 192.168.2.16
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.2.16
ip http server
ip http secure-server
ip sla enable reaction-alerts
line con 0
password 7 121A070301
line vty 0 4
password 7 1511091817
logging synchronous
login
line vty 5 15
login
version 12.2
no service pad
boot-start-marker
boot-end-marker
no aaa new-model
vtp domain CTL
no ip domain-lookup
mls qos
vlan 2
name VOIP
description AP2
speed 100
duplex full
speed 100
duplex full
mls qos trust dscp
mls qos trust dscp
mls qos trust dscp
mls qos trust dscp
interface Vlan1
interface Vlan2
no ip address
ip classless
ip http server
line con 0
line vty 0 4
logging synchronous
login
line vty 5 15
login
Once i faced same issue and changed the interface to its defaults "default interface FastEthernet0/1" and re-applied the same configs and it worked.
probably you might want to try that before planning to restart the switch.
