10-25-2012 10:45 AM - edited 03-07-2019 09:41 AM
I have a 3560-8PC in which the mgt vlan randomly (twice in one day or 2 weeks later) goes into the down state and will return w/o any interventaion 15-20 minutes later. Int G0/1 is the uplink to a 3750. I dont think its a layer1 issue at this time since i have seen it work just fine for over 2 weeks and drop again. I don't see any errors on the 3750 either.
Any thoughts appreciated. Thanks.
WS-C3560-8PC 15.0(2)SE C3560-IPBASEK9-M
LOG:
.Oct 20 19:34:37.533 EDT: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changeds tate to up
.Oct 20 19:34:38.590 EDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan20 , changed state to up
.Oct 20 19:34:39.546 EDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Gigabi tEthernet0/1, changed state to up
.Oct 20 19:34:45.527 EDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan20 , changed state to down
.Oct 20 19:34:46.500 EDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Gigabi tEthernet0/1, changed state to down
.Oct 20 19:34:47.507 EDT: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to down
.Oct 20 19:35:24.258 EDT: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
.Oct 20 19:35:25.357 EDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan20 changed state to up
.Oct 20 19:35:26.271 EDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
SwitchName#sh int vl 20
Vlan20 is up, line protocol is up
Hardware is EtherSVI, address is 6c9c.edaa.e0c1 (bia 6c9c.edaa.e0c1)
Internet address is 172.21.47.20/17
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not supported
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 2000 bits/sec, 3 packets/sec
7476765 packets input, 551439923 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
226276 packets output, 27794183 bytes, 0 underruns
0 output errors, 2 interface resets
0 unknown protocol drops
10-25-2012 12:52 PM
You need to look at the L2 connecting port for any errors. You are just looking at the L3 SVI which won't tell you anything for actual L2 port errors. Look at the actual uplink on both sides for any link errors.
10-25-2012 01:03 PM
Still dont see anything sitck out from either of the outputs.
3560-8pc:
GigabitEthernet0/1 is up, line protocol is up (connected)
5 minute input rate 81000 bits/sec, 46 packets/sec
5 minute output rate 4000 bits/sec, 4 packets/sec
135265533 packets input, 43537186577 bytes, 0 no buffer
Received 101541308 broadcasts (64799987 multicasts)
57 input errors, 25 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 64799987 multicast, 0 pause input
3750:
T1-IDF47-W#sh int g2/0/3
GigabitEthernet2/0/3 is up, line protocol is up (connected)
5 minute output rate 67000 bits/sec, 59 packets/sec
17394548 packets input, 6508502537 bytes, 0 no buffer
Received 213697 broadcasts (163949 multicasts)
0 watchdog, 163949 multicast, 0 pause input
147527710 packets output, 46332821623 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
10-25-2012 04:04 PM
Your last output is not going to help.
Please post the COMPLETE output to the "sh interface" commands and don't edit it. You've just taken out the "juicy" bits.
10-25-2012 09:30 PM
The Vlan which the SVI is for would require atleat an active port for its line protocol be come up. Assuming,
GigabitEthernet0/1 is the only access or trunk port for vlan 20 and when this went down so does the SVI associated with it.
10-25-2012 10:51 PM
Please check in the event of vlan UP/DOWN
#show mac add dyn vlan 20
Do you see any dynamically learned entries there ?
Nitin
