WS-C3560 L3 Switch ip address x.x.x.x x.x.x.x secondary
packet.tracert
I am trying to configure a secondary ip address on a VLAN interface
VLAN 10
ip address 10.10.10.1 255.255.255.0
ip address 20.20.20.1 255.255.255.0 secondary
I receive unrecognized command.
Trying to do this in packet tracer for testing.
I can do this on other manufacturer switches.
Not sure if something needs to be enabled first on the Cisco switch or it does not support it?
Amy help is appreciated..
Jason Whitehead
Hello Richard,
I happen to have 3560's in my lab, I powered them on and tested the command:
int VLAN 10
This worked without any error, I beleive this could be a limitation with Packet Tracer.
For reference I am running code:
12.2(35)SE5
Hope this was helpful
5 Replies 5
Richard Burts
I want to make sure that I understand correctly what you are telling us. You are doing this in Packet Tracer and not on a real 3560?
I do not have access to a 3560 right now to test it. But I would be very surprised if you have that error on a real switch. In Packet Tracer I am pretty comfortable that it is a flaw in PT.
Rick
Rick
Thanks for the input provided.
I guess i was wondering if i was missing something that needed to be enabled.
Naturally it could be a bug in Packet Tracer or IOS.
WS-C3560-24PS      12.2(37)SE1
Version 6.01.0011
Switch(config)#int vlan 10
Switch(config-if)#ip address 20.20.20.20 255.255.255.0
Switch(config-if)#ip address 20.20.21.20 255.255.255.0 secondary
% Invalid input detected at '^' marker.
Packet Tracer Version 6.01.0011
I can break out an old 3550 to confirm testing on, would have been nice to build it virtually instead of breaking out the switches.
Jason Whitehead
Hello Richard,
int VLAN 10
12.2(35)SE5
Thanks for doing the testing and for posting back to the forum to let us know the results. I am glad that the results show that the command works as expected on real switches and that the problem was a flaw in the implementation of Packet Tracer.
Rick
Rick
Thanks for your help, greatly appreciated!
