Showing results forĀ
Search instead forĀ
Did you mean:Ā
WS-C3560C-12PC-S
yusufbudi
Hi Team
whether the above partnumber support feature layer 3 switch like  WS-C3560-12PC-S ?
Yusuf
Sandeep Choudhary
Hi Yusuf,
WS-C3560C-12PC-S Layer Supported: 2
Layer Supported                2 to 3
These are ideal access layer switches for small enterprise LAN access or branch-office environments.
Hope it helps.
Yes, both of them support IP Base but not ip services so they will have identical layer 3 features.
yusufbudi
Dear Ovais
so the switch support feature Static routing, and RIPV1 and RIP V2  correct ?
Hi Yusuf,
Routing Protocols: OSPF, RIP-1, RIP-2, OSPFv2
It support:
  • IP Base license (formerly SMI) installed
  • Basic RIP and static routing
Hope it helps.
