WS-C3560X-24T-L and routing
dtamayonavarro
Hello
I have the following problem with a switch WS-C3560X-24T-L comes with IOS-C3560E-mz.122-55.SE5 universalk9. The role of this team is to make the routing between VLANs and access switch and the commands to make these settings are not, eg, ip rourting, router, etc..
Is not this is the team that does not support it (from what I've read if supported) or the version of IOS.
Someone could give me a hand with this please.
very grateful
atte.
Daniel
2 Accepted Solutions
Gregory Snipes
Level 4
Level 4
From what I read here I belive you are trying to perform routing on a 3560X and are having some problems.
The capabilities of the 3560X are not determined by the image on the device, they are determined by the licence file. To do routing on this device you would need to be running the IP Base or IP Services image. Here is a sheet that talks about the capabilities of each level of licence. To see what licence you are currently running, use the "show license detail" command.
Best regards,
Greg
The LAN Base licence that your device has is only capable of layer 2 function. You will need a licence upgrade for layer 3 routing. Please see the "Product Activation Process" section of the 3560X datasheet for the proper PAK part number.
5 Replies 5
Gregory Snipes
Level 4
Level 4
Best regards,
Greg
Greg
this is result of shown licencse detail
License Store: Primary License Storage
StoreIndex: 0   Feature: lanbase                           Version: 1.0
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
        License Count: Non-Counted
with this license I can't to be routing?
I need buy IP Base o IP services license?
Best regards,
ok.
thanks a lot.
Glad to help, please remember to mark correct solutions for future forum browsers.
