04-16-2013 12:24 AM - edited 03-07-2019 12:50 PM
Dear Expert,
I have a WS-C3750G-24TS-S1U. It has been used for the stack. Now I want use for something else.
I got it done factory default. I also ios recovery. But now all switchports do not work?
How can i delete? Plz help me.
Not able to open flash:/dc_profile_dir/dc_default_profiles.txt
File "flash:c3750-ipbasek9-mz.150-2.SE2.bin" uncompressed and installed, entry p oint: 0x1000000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 15.0(2)SE2, RELEA SE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 05-Feb-13 12:32 by prod_rel_team
HULC:Collect Entropy thread starting on box...
Initializing flashfs...
flashfs[2]: 2 files, 1 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 32514048
flashfs[2]: Bytes used: 17240064
flashfs[2]: Bytes available: 15273984
flashfs[2]: flashfs fsck took 2 seconds.
flashfs[2]: Initialization complete....done Initializing flashfs.
FIPS: Flash Key Check : Begin
FIPS: Flash Key Check : End, Not Found, FIPS Mode Not Enabled
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
extracting front_end/front_end_ucode_info (172 bytes)
Waiting for Stack Master Election...
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: No Cable found on stack port 1
POST: No Cable found on stack port 2
POST: PortASIC Stack Port Loopback Tests : Begin
POST: PortASIC Stack Port Loopback Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
Election Complete
Switch 5 booting as Master
Waiting for Port download...Complete
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco WS-C3750G-24TS-1U (PowerPC405) processor (revision E0) with 131072K bytes of memory.
Processor board ID FOC1234W4CE
Last reset from power-on
1 Virtual Ethernet interface
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:22:BE:B7:BB:00
Motherboard assembly number : 73-10219-07
Power supply part number : 341-0098-02
Motherboard serial number : FOC12344NCJ
Power supply serial number : AZS1227107G
Model revision number : E0
Motherboard revision number : B0
Model number : WS-C3750G-24TS-S1U
System serial number : FOC1234W4CE
Top Assembly Part Number : 800-26859-01
Top Assembly Revision Number : C0
Version ID : V03
CLEI Code Number : CNMWS00ARC
Hardware Board Revision Number : 0x09
Switch Ports Model SW Version SW Image
* 5 28 WS-C3750G-24TS-1U 15.0(2)SE2 C3750-IPBASEK9-M
Press RETURN to get started!
*Mar 1 00:02:14.788: %STACKMGR-4-SWITCH_ADDED: Switch 5 has been ADDED to the stack
*Mar 1 00:02:16.331: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Mar 1 00:02:18.621: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Mar 1 00:02:19.452: %DC-4-FILE_OPEN_WARNING: Not able to open flash:/dc_profile_dir/dc_default_profiles.txt
*Mar 1 00:02:19.452: %DC-6-DEFAULT_INIT_INFO: Default Profiles DB not loaded.
*Mar
--- System Configuration Dialog ---
Enable secret warning
In order to access the device manager, an enable secret is required
If you enter the initial configuration dialog, you will be prompted for the enable secret
If you choose not to enter the intial configuration dialog, or if you exit setup without setting the enable secret,
please set an enable secret using the following CLI in configuration mode-
enable secret 0 <cleartext password>
---------- 1 00:02:40.348: %STACKMGR-5-SWITCH_READY: Switch 5 is READY
*Mar 1 00:02:40.348: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 5 has changed to state DOWN
*Mar 1 00:02:40.348: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 5 has changed to state DOWN
*Mar 1 00:02:40.910: %STACKMGR-5-MASTER_READY: Master Switch 5 is READY
*Mar 1 00:02:42.059: ------------------------
Would you like to enter the initial configuration dialog? [yes/no]: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 15.0(2)SE2, RELEASE SOFTWARE (fc1)
