06-11-2013 07:32 AM - edited 03-07-2019 01:49 PM
Hey Guys, 3750x (2 in a stack - multiple SVI's, VLANs, ACLs) came shipped with 12.2(58) and had been put in production... Had several months without problems, however late last week there were a few trunks/portchannels added for new fit out floors, more multicast traffic too - the switch is ramping up on CPU to around 80 - 90%.
Yesterday CPU peaked 100% and dropped OSPF neighborships with a pair of ASR's at the WAN edge. Did cause a blip while the adjacencies got built again. Since the Cisco IP Phones are really flakey it was quite noticable that something had happed. But obviously the monitoring tools poll every x minutes and isnt real time.
I have already loaded c3750e-universalk9-mz.122-55.SE7.bin on the flash ready to be power cycled tonight and bring up this IOS.
Anyone see any problems with this?
Anyone experienced this before?
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
06-11-2013 07:41 AM
Bilal,
I think thats the known issue with this firmware. You can see many posts from Leo and me saying to use 122-55.SE7 to use on Cisco 3750 model.
Unless you need features in 12.2(58)SE or 15.0(1)SE or 15.0(2)SE, then I suggest you stay as far away from these.
For 3750E please use 122-55.SE7 as this is most stable and good software for this model.
Inayath
06-11-2013 07:50 AM
Thank you for confirming Inayath, I normally try and stick to 12.2 55 myself anyway.... Are there any bugs specifically related to hl3mm though - just curious why it would just shoot up like that for no reason. Apart from the fact of additional portchannel... And slightly more traffic flow.
06-11-2013 07:53 AM
I can check that for you.
By any chance do you have output of show proc cpu during that time?
regards
Inayath
06-11-2013 07:59 AM
Unfortunately I couldn't get the show proc cpu during the peak, but I can show you what its like right now, sitting around 80% - for a switch stack thats not doing a great deal :-) .... see attached.
06-11-2013 10:17 AM
Now that most users have gone home and the network has settled down, its sitting there quietly around 20 - 30%
ET-3750X-121#show proc cpu sorted
CPU utilization for five seconds: 26%/1%; one minute: 31%; five minutes: 22%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
125 4156175 3098829 1341 5.43% 5.08% 4.45% 0 hpm main process
372 194361 262380 740 2.39% 0.35% 0.20% 0 IP SNMP
10 146543 1267 115661 2.39% 0.29% 0.18% 0 Licensing Auto U
374 3431904 313484 10947 2.23% 0.35% 0.21% 0 SNMP ENGINE
214 2383054 8354164 285 1.27% 0.68% 0.57% 0 IP Input
12 219350 248412 883 0.95% 0.62% 0.72% 0 ARP Input
129 753299 121490 6200 0.79% 0.89% 0.87% 0 hpm counter proc
381 195992 676887 289 0.63% 0.10% 0.06% 0 IGMP Input
373 34206 129074 265 0.63% 0.07% 0.01% 0 PDU DISPATCHER
124 30247 10144 2981 0.63% 11.18% 3.12% 1 SSH Process
85 562244 278942 2015 0.63% 0.58% 0.57% 0 RedEarth Tx Mana
169 608417 1516804 401 0.47% 0.51% 0.38% 0 Hulc LED Process
91 292617 27014 10832 0.47% 0.31% 0.32% 0 Adjust Regions
232 190422 651990 292 0.31% 0.21% 0.10% 0 Spanning Tree
213 13677 1751429 7 0.15% 0.01% 0.00% 0 IP ARP Retry Age
382 149593 1531975 97 0.15% 0.05% 0.05% 0 PIM Process
92 7499 73688 101 0.15% 0.01% 0.00% 0 hrpc -> response
06-11-2013 05:38 PM
Bilal, There are couple of things which to be check during the issue. Like the SDM usage ,routing usage, multicast...etc...
Could of bugs to name:
CSCsm98500 3750;High CPU hl3mm proces even after multicast-routing vrf removed CSCsq20951 TEA 3750;High CPU hl3mm proces even after multicast-routing vrf remove
CSCtn42790 3560X/3750X: Elevated CPU usage due to Hulc LED processCSCtu15860 high cpu in dot1x with MDA and data vlan equals to voice vlanHTH
Regards Inayath
06-11-2013 06:17 PM
Hi Bilal,
Even though I don't know your network or your stack configuration, hands down, 12.2(55)SE7 is far superior to 12.2(58)SE (and later).
06-11-2013 10:25 PM
Thanks guys. I checked the SDM usage and we were nowhere near hitting any limits at all (during high CPU). I managed to downgrade last night but with some trouble.
Used the .bin IOS on flash and set the command, boot system switch all flash:xxxxxxx.bin.
I was SSH'd on to the stack from home, did the reload and only the master came up, the second switch didn't come up at all... Went in to check it out at midnight and second switch was powered on, but not responding at all. Fan lights were on at the back of the switch, but not even the console light was lit at the back. Consoled on to it too and still nothing.
Until I decided to give it a kick (not literally), took the stack power out and the power lead, plugged it back in and then it managed to boot properly.
Just to double make sure, I rebooted the stack again afterwards, and both came back fine.
Strange.... We'll see how it behaves today :-)
Thanks once again
06-12-2013 12:46 AM
Keep us posted.
06-12-2013 04:40 AM
This is probably a great example of what it means to downgrade to 12.2(55) - and absolutely great advice .... The difference between IOS images from 12.2(58) most left of the charts. The gap is when I downgraded to 12.2(55) and then had to go in to reboot and fix up the stack again. Quite self explanitory!
06-12-2013 03:20 PM
Nice one, Bilal!
