WS-C3750X-48P not providing POE+
Andy Koehler
I am trying to deploy a couple of new Axis P5625-E PTZ cameras, which the data sheet says requires POE+.  The datasheet also says "Camera consumption: typical 9 W, max 20W."  These are connected to a WS-C3750X-48P that is a member of a 4-switch stack.  Both cameras are showing a message on the web UI saying "Not enough power for both camera and pan tilt motors."  The output of a "show power inline" shows that only 15.4W is being provided.  I noticed on the 3750X data sheet that to provide POE+ at 30W per port, either two 1100WAC power supplies or one 1100 and one 715W power supplies are required.  Since the switch I am using only had a single 1100W power supply, I added a second 1100W yesterday.  I bounced the ports for both cameras, and no change.  I reloaded the stack last night, still no change.  Is there any other configuration required to get the switch to provide POE+ power, or is there something else I may be missing?  See below for additional relevant output from the switch showing the two ports that the cameras are connected to:
GC-TC5#sh power inline module 3
Module   Available     Used     Remaining
          (Watts)     (Watts)    (Watts)
3          1440.0      207.8      1232.2
Interface Admin  Oper       Power   Device              Class Max
                            (Watts)
*snip*
Gi3/0/40  auto   on         15.4    Ieee PD             4     30.0
*snip*
Gi3/0/44  auto   on         15.4    Ieee PD             4     30.0
*snip*
GC-TC5#sh inv
*snip*
NAME: "3", DESCR: "WS-C3750X-48P"
PID: WS-C3750X-48PF-L  , VID: V01  , SN: FDO1429P0MU
NAME: "Switch 3 - Power Supply 0", DESCR: "FRU Power Supply"
PID: C3KX-PWR-1100WAC  , VID: V01L , SN: LIT14240T7L
NAME: "Switch 3 - Power Supply 1", DESCR: "FRU Power Supply"
PID: C3KX-PWR-1100WAC  , VID: V01L , SN: LIT14220PPM
GC-TC5#sh ver
*snip*
3 54    WS-C3750X-48P      15.2(1)E1             C3750E-UNIVERSALK9-M
ahmedshoaib
Level 4
Level 4
Hi;
Use LLDP protocol to provide the power to Axis Camera. Normally Axis POE+ PTZ cameras not getting proper power via CDP.
Switch (config)# lldp run
Switch(config-if)# end
Switch# show lldp
Thanks & Best regards;
10 Replies 10
ahmedshoaib
Level 4
Level 4
Hi;
Switch# show lldp
That worked, thank you so much!
This solved my issue with an Axis Q3708-PVE.
Thanks!
@ahmedshoaib wrote:
Hi;
Switch# show lldp
Helped me today! Thank you.
Remember to rate helpful posts and/or mark as a solution if your issue is resolved.
Note that we also required a firmware update on the Axis POE cameras in combination with LLDP.
This worked for me.  Thank you!
Totto
Excellent that help me a lot.... thank you..!!!
gfillman
Good information, I will try that.  Have a Sony SRG360SHE camera that won't power up.
Hi, did you get your Sony SRG360SHE camera to work? The camera's Ethernet port lights come on, but that is all that happens. I've tried the solution listed above, but it did not resolve the problem for me.  Thanks!
Yes I figured it out, "LLDP RUN" was what finally fixed it.
Gary
