WS-C3750X DHCP configuration
Hi!
Is it posible to configure, for example two subnet (24 bit mask) for single DHCP instance (assigned to one vlan) of DHCP server on Cisco 3750X? If yes, how can I do that.
thanks for advance
Robert
balaji.bandi
Best use case is :
Network/23 is the good to go in one VLAN X
Until unless you have different requirement specific to /24 sub netonly ? why explain ?
BB
BB
thanks for the quick response.
I understand that it isn't possible...is it right?
/24 nets are the standard imposed by the company...
