WS-C3850-48P reboots with %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache)
joe.chross
The Cisco 3850 reboot after a couple of hours in operations. This has happened after the switch IOS has been upgraded from 3.2.1 to 3.3.1 however the rest of the 3850 seems to be OK except this naught one.
Below is the logs from the switch:
HOSTNAME#sh ver
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.03.01SE RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 05-Dec-13 10:15 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 1.2, RELEASE SOFTWARE (P)
--More--
HOSTNAME uptime is 14 hours, 59 minutes
Uptime for this control processor is 15 hours, 1 minute
System returned to ROM by reload at 09:03:48 GMT Wed Dec 11 2013
System restarted at 18:08:23 GMT Wed Jan 29 2014
System image file is "flash:packages.conf"
Last reload reason: reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
--More--         export@cisco.com.
License Level: Ipbase
License Type: Permanent
Next reload license Level: Ipbase
cisco WS-C3850-48P (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FOCXXXXXXX
2 Virtual Ethernet interfaces
104 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
250456K bytes of Crash Files at crashinfo:.
1609272K bytes of Flash at flash:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of at webui:.
Base Ethernet MAC Address         : XX:XX:XX:XX:XX:XX
Motherboard Assembly Number       : 73-XXXXX-XX
Motherboard Serial Number         : FOCXXXXXXXX
Model Revision Number             : L0
Motherboard Revision Number       : C0
--More--         Model Number                       : WS-C3850-48P
System Serial Number              : FOCXXXXXXXX
Switch Ports Model             SW Version       SW Image             Mode
*   2 56   WS-C3850-48P       03.03.01SE       cat3k_caa-universalk9 INSTALL
Configuration register is 0x102
HOSTNAME# sh log
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
   Console logging: level debugging, 166 messages logged, xml disabled,
                     filtering disabled
   Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
   Buffer logging: level debugging, 167 messages logged, xml disabled,
                   filtering disabled
   Exception Logging: size (4096 bytes)
   Count and timestamp logging messages: disabled
   File logging: disabled
   Persistent logging: disabled
   Trap logging: level debugging, 171 message lines logged
       Logging to 10.XX.XX.XX (udp port 514, audit disabled,
             link up),
             170 message lines logged,
--More--                       0 message lines rate-limited,
             0 message lines dropped-by-MD,
             xml disabled, sequence number disabled
             filtering disabled
       Logging Source-Interface:       VRF Name:
       VlanXXX
--More--
Log Buffer (16384 bytes):
OWN: Line protocol on Interface GigabitEthernet2/0/20, changed state to up
*Jan 29 18:09:18 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/48, changed state to up
*Jan 29 18:09:18 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan100, changed state to up
*Jan 29 18:09:18 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/6, changed state to up
*Jan 29 18:09:19 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/11, changed state to up
*Jan 29 18:09:19 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/6, changed state to up
*Jan 29 18:09:20 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/16, changed state to up
*Jan 29 18:09:20 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/18, changed state to up
*Jan 29 18:09:20 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/11, changed state to up
*Jan 29 18:09:20 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/34, changed state to up
*Jan 29 18:09:20 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/40, changed state to up
--More--         *Jan 29 18:09:21 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/33, changed state to up
*Jan 29 18:09:21 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/16, changed state to up
*Jan 29 18:09:21 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/18, changed state to up
*Jan 29 18:09:21 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/34, changed state to up
*Jan 29 18:09:21 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/40, changed state to up
*Jan 29 18:09:22 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/33, changed state to up
*Jan 29 18:09:23 GMT: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.2.0.91 port 514 started - reconnection
*Jan 29 18:09:32 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/8, changed state to up
*Jan 29 18:09:33 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/8, changed state to up
Jan 29 18:21:15 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/33, changed state to down
Jan 29 18:21:16 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/33, changed state to down
Jan 29 18:23:08 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/33, changed state to up
--More--         Jan 29 18:23:09 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/33, changed state to up
Jan 29 18:24:03 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/33, changed state to down
Jan 29 18:24:04 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/33, changed state to down
Jan 29 18:24:59 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/33, changed state to up
Jan 29 18:25:00 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/33, changed state to up
Jan 29 18:31:23 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2d6114a8
Jan 29 18:39:32 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/18, changed state to down
Jan 29 18:39:33 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/18, changed state to down
Jan 29 18:39:48 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/11, changed state to down
Jan 29 18:39:49 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/11, changed state to down
Jan 29 19:28:28 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 29 19:36:30 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/40, changed state to down
--More--         Jan 29 19:36:31 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/40, changed state to down
Jan 29 20:00:27 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/8, changed state to down
Jan 29 20:00:29 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/8, changed state to up
Jan 29 20:57:18 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 29 21:02:15 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/33, changed state to down
Jan 29 21:02:16 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/33, changed state to down
Jan 29 21:20:18 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048e1, core 2/cpu 2, cp0_errorepc == 2d8f68b4
Jan 29 21:28:12 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == ffffffff81295c98
Jan 29 21:29:18 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 560c48a8
Jan 29 21:39:20 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 58347c9c
Jan 29 21:44:24 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b1, core 2/cpu 2, cp0_errorepc == 2b666b04
Jan 29 21:49:37 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 58347cb4
--More--         Jan 29 22:00:44 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 29 22:10:11 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 29 22:22:56 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 29 23:37:18 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2d6114a8
Jan 29 23:48:01 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048e1, core 2/cpu 2, cp0_errorepc == 2d8f68b4
Jan 30 00:04:29 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == ffffffff812660b4
Jan 30 00:12:07 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 560c489c
Jan 30 00:36:04 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 30 00:41:56 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 58347c98
Jan 30 00:48:43 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 30 00:55:03 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
--More--         Jan 30 01:07:42 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 30 01:07:51 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2d6114b0
Jan 30 01:14:01 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 30 01:48:51 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 30 01:57:03 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 560c48a8
Jan 30 02:33:17 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 30 02:36:04 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 560c489c
Jan 30 02:38:55 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 30 02:55:29 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 30 03:05:02 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 30 03:14:28 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 30 03:19:17 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 58347c9c
--More--         Jan 30 03:33:09 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 560c489c
Jan 30 03:49:26 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 30 03:52:33 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 30 04:11:15 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b1, core 2/cpu 2, cp0_errorepc == 2b666b04
Jan 30 04:18:10 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b1, core 2/cpu 2, cp0_errorepc == 2b666b04
Jan 30 04:26:18 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 58347ca0
Jan 30 04:52:43 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 30 04:59:08 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
--More--         Jan 30 05:00:17 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/8, changed state to down
Jan 30 05:00:18 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/8, changed state to down
Jan 30 05:00:33 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/8, changed state to up
Jan 30 05:00:34 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/8, changed state to up
Jan 30 05:53:40 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 58347ca0
Jan 30 05:56:11 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 30 05:59:24 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 30 05:59:50 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/33, changed state to up
Jan 30 05:59:51 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/33, changed state to up
Jan 30 06:05:44 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 30 06:08:50 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
--More--         Jan 30 06:12:53 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == ffffffff815654a8
Jan 30 06:15:59 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 583d14b8
Jan 30 06:21:11 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/15, changed state to up
Jan 30 06:21:12 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/15, changed state to up
Jan 30 06:21:25 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/15, changed state to down
Jan 30 06:21:27 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/15, changed state to up
Jan 30 06:27:55 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 30 06:29:00 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/18, changed state to up
Jan 30 06:29:01 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/18, changed state to up
Jan 30 06:29:03 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/18, changed state to down
Jan 30 06:29:04 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/18, changed state to down
Jan 30 06:29:08 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/18, changed state to up
--More--         Jan 30 06:29:09 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/18, changed state to up
Jan 30 06:38:33 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/11, changed state to up
Jan 30 06:38:34 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/11, changed state to up
Jan 30 06:50:32 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 58347c98
Jan 30 06:59:22 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == ffffffff812a60b0
Jan 30 07:06:00 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 30 07:24:30 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048e1, core 2/cpu 2, cp0_errorepc == 2d8f68b4
Jan 30 07:24:58 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 30 07:31:24 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 30 07:50:24 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 30 07:56:43 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 30 08:03:02 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
--More--         Jan 30 08:03:03 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 30 08:26:17 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 58347ca0
Jan 30 08:37:26 GMT: %ILPOWER-7-DETECT: Interface Gi2/0/29: Power Device detected: IEEE PD
Jan 30 08:37:29 GMT: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi2/0/29: PD removed
Jan 30 08:37:29 GMT: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi2/0/29: Power given, but Power Controller does not report Power Good
Jan 30 08:44:20 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 30 08:53:53 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
Jan 30 08:57:01 GMT: %IOSXE-3-PLATFORM: 2 process kernel: EDAC DEVICE0: CacheErr (Icache):2521ff00000048b9, core 2/cpu 2, cp0_errorepc == 2cd694b0
7 Replies 7
Rasika Nayanajith
I think this is a software bug of this version. You should open a TAC case & confirm it with them.
Rasika
Thankx Rasikanayanajith,
I have downgraded the IOS from 03.03.01 to 03.02.03 and it has been running for 8+ hours straight now with no reboots since and seem very stable. There is load on the switch. However, I did get some error msg just recently (posted below):
Feb  3 12:42:03 GMT: Core2: 1 kernel:  Cache error exception:
Feb  3 12:42:03 GMT: cp0_errorepc == ffffffff812ab4b0 1 kernel:
Feb  3 12:42:03 GMT: CacheErr (Icache) == 2521ff00000048b9 1 kernel:
Feb  3 12:58:11 GMT: Core2: 1 kernel:  Cache error exception:
Feb  3 12:58:11 GMT: cp0_errorepc == ffffffff812ab8a8 1 kernel:
Feb  3 12:58:11 GMT: CacheErr (Icache) == 2521ff00000048b9 1 kernel:
Feb  3 13:10:06 GMT: Core2: 1 kernel:  Cache error exception:
Feb  3 13:10:06 GMT: cp0_errorepc == ffffffff812ab4b0 1 kernel:
Feb  3 13:10:06 GMT: CacheErr (Icache) == 2521ff00000048b9 1 kernel:
Feb  3 13:20:50 GMT: Core2: 1 kernel:  Cache error exception:
Feb  3 13:20:50 GMT: cp0_errorepc == ffffffff812ab4b0 1 kernel:
Feb  3 13:20:50 GMT: CacheErr (Icache) == 2521ff00000048b9 1 kernel:
Feb  3 13:47:58 GMT: Core2: 1 kernel:  Cache error exception:
Feb  3 13:47:58 GMT: cp0_errorepc == ffffffff812ab8a8 1 kernel:
Feb  3 13:47:58 GMT: CacheErr (Icache) == 2521ff00000048b9 1 kernel:
Feb  3 18:11:11 GMT: Core2: 1 kernel:  Cache error exception:
Feb  3 18:11:11 GMT: cp0_errorepc == ffffffff812ab8a8 1 kernel:
Feb  3 18:11:11 GMT: CacheErr (Icache) == 2521ff00000048b9 1 kernel:
thankx
Joe Chross
Hi Joe,
If you get TAC support reach them on this. They are the best people to assist in this scenario
Rasika
Thankx. I have just sent an email to Cisco TAC support and am waiting for their response. I hope they can help me get it sorted out asap.
thankx again.
Keep us posted with the progress as I would like to know the outcome. As this switch going to be standard access switch in my campus environment need to know these sorts of behaviour.
Rasika
RaviCepheid
202580609: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^Isyndrome: 0xb
202580610: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: Failing Address: 0x00000000d87f0320, Data: 0x0000000000000000
202580611: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: ERROR LMC0 ECC: sec_err:3 ded_err:0
202580612: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^IFailing dimm: 0
202580613: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^IFailing rank: 0
202580614: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^IFailing bank: 6
202580615: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^IFailing row: 0xd87f
202580616: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^IFailing column: 0x3c04
202580617: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^Isyndrome: 0xb
202580618: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: Failing Address: 0x00000000d87f0320, Data: 0x0000000000000000
202580619: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: ERROR LMC0 ECC: sec_err:3 ded_err:0
202580620: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^IFailing dimm: 0
202580621: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^IFailing rank: 0
202580622: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^IFailing bank: 6
202580623: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^IFailing row: 0xd87f
202580624: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^IFailing column: 0x3c04
202580625: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^Isyndrome: 0xb
202580626: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: Failing Address: 0x00000000d87f0320, Data: 0x0000000000000000
202580627: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: ERROR LMC0 ECC: sec_err:12 ded_err:0
202580628: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^IFailing dimm: 0
202580629: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^IFailing rank: 0
202580630: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^IFailing bank: 6
202580631: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^IFailing row: 0xdd5a
202580632: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^IFailing column: 0x2802
202580633: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^Isyndrome: 0xb
202580634: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: Failing Address: 0x00000000dd5a0310, Data: 0x0000000000000000
202580635: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: ERROR LMC0 ECC: sec_err:3 ded_err:0
202580636: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^IFailing dimm: 0
202580637: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^IFailing rank: 0
202580638: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^IFailing bank: 6
202580639: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^IFailing row: 0xd87f
202580640: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^IFailing column: 0x3c04
202580641: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^Isyndrome: 0xb
202580642: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: Failing Address: 0x00000000d87f0320, Data: 0x0000000000000000
202580643: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: ERROR LMC0 ECC: sec_err:3 ded_err:0
202580644: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^IFailing dimm: 0
202580645: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^IFailing rank: 0
202580646: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^IFailing bank: 6
202580647: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^IFailing row: 0xd87f
202580648: .Oct 10 08:49:08 PDT: %IOSXE-3-PLATFORM: 2 process kernel: LMC0 ECC:^IFailing column: 0x3c04
Any one can help me with this error ?
