WS-C3850-48U running 03.07.05E - Stack Member 2 - POST: Inline Power Controller Tests : End, Status Failed
david.fernandes
Hi all,
We've deployed a couple of WS-C3850-48U 3 stack members running 03.07.05E and noticed that Stack member 2 (which is also the standby) was not providing any inline power.
When troubleshooting the first stack member, we first thought it was faulty hardware but then we noticed the same issue on the 2nd stack member with the following error message from post:
Switch 2
POST: CRYPTO Tests : Begin
POST: CRYPTO Tests : End, Status Passed
POST: PHY Loopback: loopback Test : Begin
POST: PHY Loopback: loopback Test : End, Status Passed
POST: Inline Power Controller Tests : Begin
POST: Thermal, Temperature Tests : Begin
POST: Thermal, Temperature Tests : End, Status Passed
POST: Thermal, Fan Tests : Begin
POST: Thermal, Fan Tests : End, Status Passed
POST: SIF Tests : Begin
POST: SIF Tests : End, Status Passed
Has anyone else run into this particular issue? Thought it might be related to:
CSCuy99151 3850 failing Inline Power Controller Tests
but per the notes here:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/3e/release_notes/rn-3dot7e-3850.html
that bug was addressed in the 03.07.05E release.
Leo Laohoo
Raise a Cisco TAC Case.  I suspect this is a bug.
You could verify this by downgrading to, say, 3.6.6E and see if the same behaviour exist.
Thanks Leo. Yep, were going that route. Was just a bit curious if anyone else ran into this.
Will post if we do find out it is a bug. Thanks!
