WS-C4500X-16 is in rommon mode and unable to recover itc
Sri v
Hi All,
I have a new cisco device with the model of  WS-C4500X-16, when i power on it displays the below error and goes to rommon mode.
* Rom Monitor NVRAM configuration is being initialized to      *
* default values. This may be because it was never initialized.*
Writing to Primary Region failed
Writing to Backup Region failed
Rommon (G) Signature verification PASSED
flash0:/codesign/rm1.dat open failure
Rommon (P) Signature verification PASSED
flash0:/codesign/rm2.dat open failure
FPGA   (P) Signature verification PASSED
flash0:/codesign/fpga.dat open failure
* Welcome to Rom Monitor for    WS-C4500X-16 System.       *
* Copyright (c) 2008-2012 by Cisco Systems, Inc.           *
* All rights reserved.                                     *
Rom Monitor (P) Version 15.0(1r)SG6
CPU Rev: 2.2, Board Rev: 4, Board Type: 108
CPLD Mobat Rev: 2.0x4377.0xb277
Chassis: WS-C4500X-16
MAC Address  : f0-f7-55-c5-31-7f
Ip Address   : Not set.
Netmask      : Not set.
Gateway      : Not set.
TftpServer   : Not set.
Non-Redundant system or peer not running IOS
System Uplinks & Linecards have been reset!!
***** The system will autoboot in 5 seconds *****
Type control-C to prevent autobooting.
******** The system will autoboot now ********
config-register = 0x102
Autobooting using BOOT variable specified file.....
Could not find a valid file in BOOT environment variable.
BOOT variable can be set from IOS. To find currently set
Rom Monitor variables, please type 'set' command.
For help on choosing a boot method,  type 'confreg' command.
So i try to see the image in the bootflash, if i execute the dir bootflash:, It displays as below and doesn't showed the content
rommon 1 >dir bootflash:
ExtX super block invalid signature
So i thought of booting the device with usb but no pendrive gets detected .it also fails as u can see below
rommon 2 >dir usb0:
No USB storage device detected!
Error[3]: Failed to open directory!
Can anyone suggest me what i can do further
7 Replies 7
Leo Laohoo
RMA the appliance as "Dead On Arrival".
Thanks for the reply...
Is there anything that we can troubleshoot ?
The appliance is dead.  It should still be covered under warranty.
Hello Sr,
It is possible that we may a faulty appliance nevertheless try the next action plan:
1- Change the config register to 0x2102
   --Check the settings
   rommon>set
   --Clear the current boot variable
   rommon>unset boot
   rommon>confreg 0x2102
   rommon>reset
If does not fix the issue follow step 2:
2- Connect the management port to access a tftp server.
   You will see a message that a physical link is established
   --Issue the set interface gi1 or fa1
   --rommon>set interface fa1 x.x.x.x 255.255.255.0
   DG to use to get to the TFTP server
   --rommon>set ip route default x.x.x.x
3- Check that the configs which have been made and test connectivity
   rommon>set
   rommon>ping x.x.x.x
4- Once the ping to the tftp is successful, you can issue the boot tftp to specify the image:
   rommon>boot tftp://x.x.x.x/
If the switch comes up we need to copy the image onto the bootflash and change the boot variable again and wr
RMA will the last option if no luck.
Haihua
Thanks Haihua Rong,
This is really helpful for me, my issue is resolved. Thanks again..! and keep helping to others..!
   rommon>set
   rommon>unset boot
   rommon>reset
this Steps got Succeed
This Solution one , did help. Thanks a lot.
