WS-C4500X-32 Optical RX power Alert
Szabo Tomi
Hello Everyone,
I got many snmp alert from WS-C4500X-32, for example Te1/1/2 Optical RX is to low (-40).
Which is wired, I have never connected SFP modul at this port, and the ports config is empty.
But, if I checked the inventory the switch says the SFP moduls details, and the port phisicaly empty.
I attached some log.
HUTATNSFA001#sh run int ten 1/1/2
Building configuration...
Current configuration : 51 bytes
interface TenGigabitEthernet1/1/2
shutdown
end
HUTATNSFA001#sh int tran det
Optical High Alarm High Warn Low Warn Low Alarm
Receive Power Threshold Threshold Threshold Threshold
Port (dBm) (dBm) (dBm) (dBm) (dBm)
Te1/1/1 -7.6 2.9 0.0 -17.0 -21.0
Te1/1/2 -40.0 2.9 0.0 -17.0 -21.0
HUTATNSFA001#sh inventory
NAME: "TenGigabitEthernet1/1/2", DESCR: "1000BaseSX"
PID: GLC-SX-MMD , VID: V01 , SN: OPM22180S4Q
HUTATNSFA001#show idprom interface tenGigabitEthernet 1/1/2
GBIC Serial EEPROM Contents:
Common Block:
Identifier = SFP [0x3]
Extended Id = GBIC is compliant with MOD_DEF 4 [0x4]
Connector = LC Connector [0x7]
Transceiver
Type = Gbic 1000BaseSX
Speed(FC,byte 10)= Not available [0x0]
Media = Not available [0x0]
Technology = Not available [0x0]
Link Length = Not available [0x0]
GE Comp Codes = 1000BASE-SX [0x1]
SONET Comp Codes = Not available [0x0]
10GE Comp Codes = Extended [0x0]
Encoding = 8B10B [0x1]
BR, Nominal = 1300 Mbps (million bits per second)
Length(9u) in km = GBIC does not support single mode fibre, or the length
must be determined from the transceiver technology.
Length(9u) = GBIC does not support single mode fibre, or the length
Length(50u) = 550 m
Length(62.5u) = 290 m
Length(Copper) = GBIC does not support copper cables, or the length must
Vendor name = CISCO
Vendor OUI = 2589
Vendor Part No. = TRPUG1ESXECISE2G
Vendor Part Rev. = 01
Wavelength = 850 nanometers
CC_BASE = 0xF4
Extended ID Fields
Options = Loss of Signal implemented TX_FAULT signal implemented TX_DISABLE is implemented and disables the serial output Linear Receiver Output implemented [0x1A]
BR, max = Unspecified
BR, min = Unspecified
Vendor Serial No. = OPM22180S4Q
Date code = 180513
Diag monitoring = Implemented
Calibration type = Internal
Rx pwr measuremnt = Average Power
Address change = Not required
CC_EXT = 0x47
Vendor Specific ID Fields:
558BC37C 00 00 03 18 20 94 BA EE 03 B5 01 56 EE 21 3F 94 .... ^T.n.5.Vn!?^T
558BC38C C9 97 39 00 00 00 00 00 00 00 00 00 B7 27 40 41 I^W9.........7'@A
SEEPROM contents (hex) size 128:
0x0000 03 04 07 00 00 00 01 00 00 00 00 01 0D 00 00 00 ................
0x0010 37 1D 00 00 43 49 53 43 4F 20 20 20 20 20 20 20 7...CISCO
0x0020 20 20 20 20 00 00 0A 1D 54 52 50 55 47 31 45 53 ....TRPUG1ES
0x0030 58 45 43 49 53 45 32 47 30 31 20 20 03 52 00 F4 XECISE2G01 .R.t
0x0040 00 1A 00 00 4F 50 4D 32 32 31 38 30 53 34 51 20 ....OPM22180S4Q
0x0050 20 20 20 20 31 38 30 35 31 33 20 20 68 F0 02 47 180513 h..G
0x0060 00 00 03 18 20 94 BA EE 03 B5 01 56 EE 21 3F 94 .... ^T:n.5.Vn!?^T
0x0070 C9 97 39 00 00 00 00 00 00 00 00 00 B7 27 40 41 I^W9.........7'@A
Thank you for your help!
Best regards,
Tamas
marce1000
 - Could be a software bug. Depending on priority you may evaluate more recent software release(s) for your platform.
 M.
marce1000
 M.
Dear Marce,
Thank you for your reply.
The IOS version is Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.08.07.E RELEASE SOFTWARE.
I try to update to the latest suggested IOS.
Thank you,
Tamas
