04-13-2011 10:19 AM - edited 03-06-2019 04:36 PM
Is it possible to copy the Ws-C4506-E configuration to a WS-C4503-E ? how can I make it ?
Thanks a lot
Solved! Go to Solution.
04-13-2011 10:22 AM
Well yes it is apart from the obvious issue of having only 2 modules in the 4503 + sup whereas you have 5 modules + sup in the 4506.
If you only had 2 modules in the 4506 and you could move them to the same slots in the 4503 then you could just cut and paste. If you 2 modules in the 4506 but in different slots eg. slots 5 & 6 then you could do a quick bit of editing to change the slot number and then paste into the 4503.
Jon
04-13-2011 10:22 AM
Jon
04-14-2011 01:26 AM
Thanks Jon for your your answer.
