WS-C4507R+E chassis with WS-X45-SUP7-E supervisor module with LANBASE license - Does it support IGMP snooping?
Difan Zhao
Level 5
Level 5
Hi experts,
As in the topic, does LANBASE support IGMP snooping?
If I want to run PIM Sparse mode, do I need to go to IPBASE or Enterprise?
Is there a Cisco website which lists the supported features of a given license for switchs or routers?
Thanks!
Difan
Reza Sharifi
IGMP and IGMP snooping is support with Lan Base image
if you need PIM then you need IP Base or IP services image
have a look at table-1 in this link
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/release/note/OL_5184.html#wp2536140
Thank you Reza
