Protect Loopback
Krasnoperov
how can I protect my loopback interface, extended ACL doesn works :-(
interface Loopback 1
ip address 1.1.1.1 255.255.255.128
ip address 1.1.1.2 255.255.255.128 secondary
ip address 1.1.1.3 255.255.255.128 secondary
ip access-group JUST_ICMP in
ip access-list extended JUST_ICMP
permit icmp any host 1.1.1.2
deny any any
When I ping from remote-->1.1.1.3 it's pingable and no matching in ACL (even in deny)
Why?
thanks
Richard Burts
To protect the loopback interface it does not work to put the access list on the loopback interface itself. You would need to put the access list on the interface on which the packet got to the router. So you potentially would need the access list on several interfaces.
The reason for this is that when you ping a router interface the router does not send the ping all the way to the destination interface. When a packet comes in a router interface and the router looks at how to forward the packet and finds that the router is the destination then the router just processes the packet and does not send the packet all the way to the destination interface.
Rick
Rick
Richard Burts
Rick
Rick
