WS-C4507R+E vulnerability issue
Running image cat4500-ipbasek9-mz.150-2.SG11.bin we have faced vulnerabilities
CVE-2015-6375
CVE-2015-0204
CVE-2017-3881
cisco-sa-20170419
cisco-sa-20170629
CVE-2017-6770
CVE-2017-12240
CVE-2018-0174
CVE-2018-0175
CVE-2018-0172
CVE-2018-0173
CVE-2018-0167
CVE-2018-15369
CVE-2018-15373
CVE-2018-0197
CVE-2018-0475
i had checked all CVE ids there is no work around. also installed image latest only. how can i fix this issue any one help this bug fix?
16 Replies 16
Thank you for updating. I agree with your reports. May i know is there any option without replacement of hardware.
Your only option would be to remove some of the offending features. TACACS could be swapped for RADIUS, DHCP relay implemented on another device.
Beyond that, you need to evaluate how exposed you are to malicious actors who could attack you. If you are routing guest traffic through the switch, then you have no control the devices. However if all your traffic is fro enterprise devices, (ie locked down, unable to install unauthorised software) then it is unlikely you could be attacked.
If your organisation values data security, flag these issues with the to show you have evaluated the situation, make a hardware upgrade recommendation and leave it in managements hands. If a security breach occurs as a result of these flagged vulnerabilities, you have done all you can, it will be their head that rolls.
cheers,
Seb.
