WS-C4510R-E boot flash command
ROSS FITHERIDGE
Hello ,i was putting new image on 4510 just wanted to check if below command in need to put on or is ther some other syntax
boot system flash bootflash:cat4500-ipbasek9-mz.122-53.SG9.bin   <--- is command which i have placed
SW001#sh bootflash:
-#- ED ----type---- --crc--- -seek-- nlen -length- ---------date/time--------- name
1   .D image        FC388696  BD0F08   33 12127880 Feb 11 2009 07:51:44 +00:00 cat4500-ipbase-mz.122-31.SGA8.bin
2   .. image        3CFF21B7 1A23254   32 15016652 Apr 21 2009 04:23:34 +00:00 cat4500-ipbase-mz.122-50.SG1.bin
3   .. image        0EBE4848 29A2654   34 16249728 Oct 8 2013 04:57:10 +00:00 cat4500-ipbasek9-mz.122-53.SG9.bin
17947052 bytes available (43394644 bytes used)
InayathUlla Sharieff
Ross,
I think you should be good to go.
The file is uploaded on to bootflash and you are seeting the correct boot system.
YOu can go ahead with your plan.
REgards
Inayath
