06-19-2018 08:25 PM - edited 03-08-2019 03:24 PM
Hi guys,
I am planning to install 2 mGig modules (WS-X4748-12X48U+E) on a 4507+E chassis.
Can it support 2 of these mGig modules ?
Is there a limitation on how many can be installed on each chassis type for example 4510+E?
06-20-2018 11:23 AM
see table-3 in this link:
5 WS-X4712-SFP+E and WS-X4748-12X48U+E are not supported on 4507R-E and 4510R-E chassis.
06-21-2018 05:58 AM
Yes but mine is the +E models.
thanks.
06-28-2018 12:25 AM
The Cisco Catalyst 4500 Series is a centralized architecture that is designed to provide dedicated wire-speed bandwidth to each line-card slot within the chassis. Each line card has a dedicated bandwidth to the supervisor engine for packet processing. All network data that flows into the Cisco Catalyst 4500 Series through the various line cards goes through the supervisor engine for processing, even in single-slot port-to-port communications. All line cards have some per-slot bandwidth that allows network administrators to design a system that offers full dedicated bandwidth-to-server and switch-to-switch applications and still provides high performance over subscribed gigabit to the desktop.
Following are descriptions of line cards that are available for Cisco Catalyst 4500 Series Switches.
Cisco Catalyst 4500E Series 10 Gigabit Ethernet Fiber Line Card
WS-X4748-12X48U+E:
● 48 ports with 12 multigigabit ports and 36 10/100/1000 ports
● Campus ready for next-generation wireless connectivity to NBASE-TTM compatible endpoints such as 802.11ac Wave2 multigigabit access points, multigigabit switches, network interface cards (NICs), and adapters
● Speeds of 100/1000/2.5G/5G/10GBASE-T on the multigigabit ports and 10/100/100 on the other ports
● Three flexible software-configurable modes to optimize for 10/100/1000 or multigigabit operation
● Nonblocking up to 1000 Mbps on all ports
● RJ-45 support on all the ports
● Cisco IOS XE Release IOS-XE3.7.1E or later
● UPOE: capable of up to 60W per port up to 1440W
● Energy Efficient Ethernet 802.3az on all the 10/100/1000 ports
● IEEE 802.3af/at and Cisco prestandard PoE, IEEE 802.3x flow control
● IEEE 802.1AE and Cisco TrustSec capability in hardware
● L2-4 Jumbo Frame support (up to 9216 bytes)
● Capable of up to 30W of inline power per port on all ports simultaneously
● Enterprise and commercial: designed to power next-generation IP phones, wireless access points, wireless base stations, video cameras, virtual desktop clients, and other PoE/UPOE devices
● Campus and branch applications requiring enhanced performance for large file transfers and network backups
06-28-2018 05:06 AM
